i have a whirlpool side by side with a broken water line inside freezer door. can i replace it and how? model is ed5phaxsboo
Yes, it can be done. You have to order new fitting kit. The instructions are attached to the reply.
- The fitting AP3179954
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136997&diagram_id=931558
i have a kenmore side by side that i need to change the water line in the freezer door as well… model number 106.56663500. how do i get to the waterline to replace it?
Did you read the previous post?
The instructions are attached to it and you can use the same part number.
— Begin quote from lad740;236302
What if I have a GE side by side Gss25sgmdbs? The line is cut at the bottom hinge, so I need to replace the line. Is it the basic same assembly or is something else needed?
— Begin quote from eugermach;768614
It is more complicated with this refrigerator. Click on the part number or picture bellow and scroll down to the Q & A section for the installation instructions.
- The tube assembly WR17X11116
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100411
P.S. It is possible that you will have to remove the inner door panel to do this job.
Gene: Thanks, that was the part I thought I needed, but is there anywhere where I can determine if door panel needs to be removed. I thought I would be able to take apart the ice maker panel, and pull the tube out and rethread. The diagram from GE does not indicate how the line is threaded through.
Any direction would be appreciated.
— Begin quote from Gene;768794
…Click on the part number or picture bellow and scroll down to the Q & A section for the installation instructions…
Did you do it?
Gene:
I got the part, but I am not sure how this escutcheon or trim plate is removed. I do not want to break it, and am not positive on how to remove. Any help to get it off will be appreciated. Some forums discuss pushing and removing by the tabs. Not sure how it works.
[SIZE=3]I went to Ace and bought 6 inches of rubber water hose, $1.89 that would fit both side and used hose clamps. Cut out hole and attach hose and use the hose clamps. Mine has been working ever since, for years, mine is a GE pss29ngmbcc. The water line cracked in two places where the line bent to sharp when it was only 2 years old. GE wanted $275 to replace the line. GE should of just used good plastic hose intead of being CHEEP.[/SIZE]
— Begin quote from eugermach;769965
Gene:
The instructions are attached to the reply. There is nothing too difficult.
— Begin quote from Gene;770139
Tried that, but it only got me to the chute flapper section. It doesn’t appear that section can be removed to get to the hose (which appears to be screwed in behind the section. I looked in the tech manual that you got this from, and it appears to indicate that I would have to remove the door panel and insulation and gasket to get to the screws for removal. Not sure, but unless you have another method, I will be trying that next.
— Begin quote from eugermach;770177
…I would have to remove the door panel and insulation and gasket to get to the screws for removal…
Looks like that this is the only way to do it.
