The Washing Machine Will Not Spin Or Drain. It Fills Up And Agitates Just Fine. I Took Off The Drain Hose And It Was Not Clogged. The Washer Worked The Time Before With No Problem.
I Hope You Can Give Me Some Suggestions To Fix This.
Thanks,
Bruce
By pass the lid switch and see if that causes it to drain and spin. If so, replace the lid switch.
This site will tell you how to do that. Note: By pass if for test purposes only, do not operate the machine like that.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
