Burner Control Knob
One of my burner control knobs does not turn. I can push it down, but it will not turn. Do I need a new burner valve? What would a technician charge to replace this? Thanks
Hi.
Most likely you do need a new burner valve. Don’t force it, if you brake it there will be gas leak.
Check the price with you local repair companies.
Thank you.
Simon.
