Burner wont spark
My front right burner will not spark. I switched it to the back and it worked. So im assuming i should change either the valve switch or valve control. Does anyone have any input before i order these parts. Id hate to order them and its something else. Thanks!!!
Hi.
Check the burner switch for the continuity first.Unplug the unit, remove the wires from the switch. Set the switch in question to light position and using a multimeter see if there is continuity.
No continuity - replace the switch [part]WB24K14[/part]
Unfortunately the spark module’s picture and it self are not available. I can’t get you the part number but if you can post the picture of it we may get you the replacement if needed.
Here are the breakdown diagrams and Burner Assembly parts for GE JGBP35GEP3 - AppliancePartsPros.com
Simon.
