burners work but oven will not light
My Maytag model MGR5755QDW will not light it stays at 100. No gas smell. gas burners on the top work fine? help
— Begin quote from jwohlf;417627
Jwohlf,
Remove the bottom panel in the oven and observe the glow bar igniter,
after you program a bake cycle, the igniter bar should start to glow, it will take a few seconds the bar should be "white"hot in less than 90 seconds, then it should release and ignite the gas. if it doesnt glow or if it only glows orange/red, you most likely have a weak/bad igniter,
[part]AP4012072[/part]
Good Luck,
