I have a problem similar to what others have posted but I have done much more debugging and it is still not clear to me what is wrong.
A little background first:
For the last month or so I have been hearing a new noise from the fridge. It sounds like a click, then a buzz, then after about five seconds, another click and silence. At first I thought the ice maker had changed its sound but later found out it was not.
So this morning the machine was on and was not cooling anymore. I pulled it out from the wall and pulled off the front grill. Of course there was a massive amount of dust clogging the cooling coils underneath and also behind the unit. After vacuuming up the dust the fridge was able to cool for a while but then the sound returned and cooling diminished.
Diagnostic time:
I pulled of the back panel and determined the click-buzz-click was coming from the electrical components on the side of the compressor. I looked up the parts on this website and found that it was a "Compressor starting device" that was making the sound.
After doing some Google searching on this I found this nice article describing the components, what they do, and how to test them: [U]http://tech.akom.net/archives/31-Getting-your-refrigerator-to-run-without-a-start-relay-while-you-wait-for-the-part.html.[/U]
I removed the "Compressor starting device" pulled it apart and measured and inspected all the sub components. Everything looked fine with no sign of burning. The capacitor measured correctly (15 uF). The relay (overload cutoff device?) was conducting as was the thermistor (PTC). I measured the resistance across the terminals of the compressor and found 4, 5, and 10 ohms between the pairs which seemed proper given the webpage I linked to above.
Dilemma:
Yet the problem persists. So given that all the components look good yet the machine still goes into the click-buzz-click mode, how do I figure out what is wrong? Is it worth it to just buy the "Compressor starting device" to see if it fixes the problem. It seems like these devices don’t go out of spec, they just die so I am not sure if. But if the compressor is the problem then the whole thing is junk (right?) so it is cheap to at least try the "Compressor starting device".
Thoughts?
