Buzz in gas dryer when burner is on
Maytag gas dryer runs and cycles OK, however there is a very annoying buzzing sound when the burner is lit. When you turn the dryer on it fires and runs quiet through the first cycle. Then when the burner fires the 2nd and on all succeeding cycles there is an annoying buzz. The sound seems to be coming from near the burner area or in that lower area of the dryer.
I replaced both coils, still same problem.
The sound seemed to be coming from the thermostat-fix switch (FSP8318268) area so replaced it, still same problem.
Any Ideas???
— Begin quote from BirdHunter;592948
Any Ideas???
Sure need any help or ideas that nayone can give me.
BirdHunter.
Anybody out there who has suggestions or ANY Ideas of what for me to check NEXT???
Getting lots of static from the better half on the buzz.
Thanks in advance for any HELP.
BirdHunter
