Cabrio spnning issues
needing some advice, have an older model but it still ran great up until this summer. Had horrible grinding noise last year–and then it stopped spinning this summer–yes I know we should have addressed it earlier but that didn’t happen. fast forward to now–we have replaced the shift actuator, basket drive block, gear case and now the motor drive—the thing still does not spin or agitate–it will run through the cycles fine-- and after we replaced the motor drive the only code that I still get is the F7 E6–which is the motor drive… I will sat that my husband did not check the new motor with that ohm meter–he did recheck all the connections to make sure they were secure —so I’m at a loss–is it time for a new machine?? ugh I hope not --any help would be great–thanks Robin M.
