After starting a load to wash, the unit will shut down and show F1 on the display. By pressing the cancel/pause button and then the start button it will start again and continue the run but will stop at various points along the cycle which will require pressing the cancel/pause button and the start button each time it stops to eventually get it through the complete cycle.
Before buying the an electronic control board or user interface board, I would appreciate your advise and recommendation as to what the cause could be and proper repair procedure.
Glenn
