I am truly sorry but I cannot find my answer to the question I posted which was my Front Load Washer is not draining towards the last 18 minutes of its cycle, I would like to check the filters and don’t know where its located what panels needs to be removed this is my final attempt. I would like to thank those responsible for trying to answer my question. Thank You Jerry:)
Remove the bottom panel by remove the screws at the very bottom. Once removed you should see the water pump. On the water pump there is a clean out (right in the front) that you can remove by just unscrewing. When you do this all the water in the tub will come pouring out the clean out so be ready. Once you get the clean out you can get anything that may be clogging the pump. If nothing is in the pump you may have to replace the pump. http://www.appliance-repair-it.com/clothes-washer-repair.html
