can't make inputs
Hi, I have a GE profile microwave about 5 yrs old. The window says set time but I can’t input anything. Is that the control panel or the key pad that is dead. :confused: Any help :slight_smile:
Trey
Hi Trey,
The model number you posted does not come up. Verify and repost it please.
Hi Gene, thanks for the reply. My mistake this is the correct model number
JVM1870BF03
thanks
Trey
JVM1870BF03
thanks
Trey
JVM1870BF03
thanks
Trey
Trey,
Most likely the problem is a bad key panel. If you need the correct part number, post the color of it.
Here are the breakdown diagram and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5222004
Gene said:
Trey,
Gene, the color is black.
Thanks so much
You are welcome Trey.
The black key panel AP3203231
