Changed the large front duel burner element. Still doesn’t work. All the other burners work. Do you have any suggestions? Thank you.
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MES5870AAW
Did the new element include the limiter?
If not then the limiter may be blown (open).
If yes then it is probably the infinite control switch.
There is always a slim possibility that the replacement element is no good.
Would be best to check it with a meter.
looks like I will need a infinite control switch for the duel large burner. can you help me with a part #. thank you for your help
It is best to call and talk to the parts people as they have up to date info.
I do not work for AppliancePartsPros so the info you see is the same as mine.
okay
thank you!
