Changing JennAir burner
The front right burner on our cooktop has stopped working. It is the dual element burner. I flipped the breaker and the touch pad would respond but no heat. The burner is listed here as available but before I get one I would like to see some instructions just how to do it.
Hi.
You will need to pull the cook top out. When you do that you’ll see the screws around the perimeter.
That what is holding the top.
Don’t forget to turn the power off!
Thank you.
Simon.
