chwn2001
Frigidaire PLHS269ZDB2–I replaced water dispenser actuator, but while doing that, the ribbon cable was accidentally unplugged. I put everything back, turned on the power, the Ice dispenser auger runs non-stop. Here are the things I’ve tried:
  1.  Disconnect the wire on micro switch for ice dispenser, the auger still runs.
  2.  Re-connect the micro switch, and disconnect the ribbon cable, then ice auger stops.
When power is on and Ice dispenser auger running, all the lights on control board (AP3963433 are[COLOR=black] on except the lock light. When I push any buttons on the control board, no response, no light will be off, they all stay on. If I push and hold the lock button, the red lock light will be on. With lock light on, I opened the freezer door, auger stops; closed door, auger still off; push and hold the lock button again, lock light off and auger runs again and.
[/COLOR]
Is this a problem with control board ([URL="http://www.appliancepartspros.com/Appliance-Parts/frigidaire-board-control-item-number-ap3963433.aspx)) or power board( AP3965513)? Or something else?
[COLOR=black]
[/COLOR]
