Circuit board or Controller Repair Options
I know this may seem like an obvious time to replace an over, but I’d like to try and find a replacement part (listed as not available online) for my Maytag oven. The oven itself still looks and performs like it’s brand new, but the control panel has been behaving strangely lately. Every now and then it just beeps and flashes the cook time set or time set controls. Between times it operates fine and I’m able to set the oven temperature and it heats up with no problem.
But on a couple of occasions I would hit the temperature set button and nothing would happen, I wasn’t able to set the temperature. Before that condition is permanent, I’d like to find out if there is anywhere out there online where old parts (as-is or reconditioned are available). I’d rather keep this one going because it’s still in mint condition and am a bit freaked out at the idea of trying to find another oven that will fit into the existing cut out and not make for a horrible cut/paste/patch experience. Sure it’s kind of broken and I prefer to fix it than replace it with a newer version. Can the board/controller itself be fixed if all else fails?
Thanks,
PJF
