Circuit Breaker Trips when Mircrowave is turned on
The circuit breaker trips everytime the microwave model GE JVM1650CH01 is turned on to cook. All other features works, i.e. lights, vents, clock.
— Begin quote from abadfish66;23913
Is there a loud buzzing noise when you hit start and before the breaker trips? Your either going to be looking at a weak house breaker, or a shorted transformer in your microwave. Run an extension cord from the microwave to a different outlet and see if it trips that breaker, if it does your transformer is bad. Only run the micro on the extension cord for a short time, 10-15 seconds, as the added resistance in the extension cord will trip the breaker as well.
I already tried running the Microwave using the extension cord to a different outlet, it also trips the breaker on that outlet. I did not notice a loud buzzing noise before the breaker trips.
Sounds like your high voltage transformer has a short to ground
