clock assembly
Hi! I just replaced the clock assembly on this oven because the display stopped working. The problem is the new one does the same thing? Is it possible that I got a faulty clock assembly or could it be something else. Also, the oven will operate (self clean, all the buttons work) but there is no display. Thanks!!
Most likely the new clock assembly is defective. Whoever sold it to you, has to exchange it.
Here are the break down diagrams for the Magic Chef range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=700039&&model_id=42145
