I have a Frigidaire front loading washing machine and when it is finished the clothes are still wet. The pump was removed, the drain was not stopped up and we thought the pump was bad. A new drain pump was put on but it still doesn’t spin fast. The tub will go around and wash but it does not spin fast. What else could be the problem.
If you will post a model number so we can see exactly which machine you have we may be able to give some advice.
Model ltf2140es3. I did the diagnostic test and it might be the control board. The cheapest I have found is 137.00. I can’t keep putting on these expensive parts. Thanks for any output.
A more likely problem is the machine speed control board. What diagnostic error message did you get from the tests?
I sympathize with you spending money on a pump that did not fix things.
Unfortunately you will probably not know for certain about which board to replacing without replacing it, this is the bane of microprocessor controlled machines.
Product: Frigidaire 3.5 Front Loading Washer
Model # LTF2140ES3
I have a similar problem.
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled boot.
Error message 43 which indicates control board problem. I ordered control board part# 13700500 Installed- same error message. Unit will not spin. Will operate through all cycle and stops at spin. Ran diagnostic test. Turned program knob 8 clicks from start to position 8- Delicate. The drain pump and door lock solenoid will activate and the washer will operate in high spin and drain. Error code 43 repeats.
