Clothes no longer getting fully dry on automatic cycle
Hey All-
My Whirlpool GGW9200LW1 is no longer getting the clothes fully dry on the automatic cycle.
I checked the exhaust ducting for problems, but there were none to be found. The run is less than 4 feet, it has only two 45 degree bends, and it is completely free of any blockage.
I ran the diagnostic test I found by checking the net and all was fine except for the code displayed when I did the moisture sensor check. I got a code of 02 instead of 03, but cant find any information on what that means. I checked the thermistor and gas valves with an ohm meter and they were in the normal ranges. The moisture sensor wires are not shorted out, and when running automatic cycle, the indicator lights progress from "wet" to "damp" to "sensing" as the clothes get dryer. I have taken the front panel off and watched as the dryer cycles and all seems to work fine. As the ignitor get hot the gas comes on every time and it fires off.
Am I missing something, or is the control panel going bad?
I dont want to throw this dryer out, but I am at my wits end…
I would take the dryer apart and check the blower housing for lint build up.
