Dryer heats up in a normal cycle, clothes are not totally dry.
The coils come in a set of two, and are available from a few manufacturers. One part number is 5303931775. Thats a frigidaire number, but the coils are all the same. What I mean by 5-10 ignitiong is that the burner cycles on, and off 30-40 times in a drying cycle. Each time it comes on, the igniter comes on, then the coils open the gas valve. When you first start the dryer it may get hot, but then after a few minutes it will stop heating. It will still run, just wont heat. It could also have a bad blower wheel, but that will usually make a rumbling sound when the dryer stops and starts.
NEED step by step to tighten handle
— Begin quote from fidel.medina@comcast.net;359638
Not tobreak seals if any
— Begin quote from fidel.medina@comcast.net;359639
