Dryer heats up but no air flow. Already checked for lint build up.
Hi.
If you don’t have air flow with the vent disconnected from the dryer the first thing to check is the blower. Open the blower housing and check it the wheel is not spinning free on the shaft. Also check all internal air ducts for blockage.
Here are the breakdown diagrams and Replacement parts for Magic Chef YG205KW DRYER- GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
