clothes to wet
clothes is to wet after a spin cycle
clothes is still soaking after a spin cycle
Look to see if there is a partial blockage in the drain hoses inside the machine. Then operate it with the front panel off to see if the spin is fast enough. If the spin is a problem try changing out the thrust bearing with this kit here.
AP4009132
