Last night, the drive belt on my Neptune TL started to squeal at the start of the wash cycle (I think). Has the clutch seized? I can easily rotate the inner drum by hand in the CCW direction, but it immmediately locks up in the CW direction. I have removed both tumblers and there is nothing jammed in the gear driving each one. Could something have gotten jammed inside the transmission or maybe I have bad bearings? Is my next step to remove the tumbler bearings then the transmission and spinner from inside the wash tub (I have the service manual)? Since this is a series 15 machine, is Part Number 12002211 the correct clutch and pulley assembly? What other parts (bearings, seals) should I replace while I have it apart? Thanks in advance for any help
Related topics
FAV6800 series 15 bearing replacement | 1 | 645 | November 17, 2014 | |
Clothes still soaked -- NeptuneTL - still stumped | 20 | 4184 | August 16, 2010 | |
Water leak | 3 | 1555 | January 29, 2011 | |
Maytag Neptune TL Stops in Wash | 7 | 9857 | June 3, 2012 | |
FAV6800AWW Clutch Issue - Signs of Water Leak | 4 | 4540 | April 18, 2011 |
