Code F9 & dr
Hi,
I went to do a self clean for the first time ever on this oven. The door locked and F9 code and beeping. I went to check door switch and it broke coming out. I ordered new one and put old one back together and it tested good w/DVOM. I also checked the door lock micro switch w/DVOM and it too checked OK. Open when door lock unlocked, closed when iI depress lever. Any ideas.
Thank You,
BWES88
To all out there on this forum. I fixed my oven Code F9. It was a clock assembly (EOC) that was bad. I was lucky that my friend was over on New Years Eve and was junking his simular range. I went and salvaged the part and all is well.
