Coincident or serious problem
Roper dryer does not heat.
About two weeks ago the dryer stopped heating, I installed a thermal cutoff kit. The dryer has been used many times since then. Today it stopped heating again. I will check continuity of other parts to find what is wrong. I am wondering if there is something wrong with the dryer - like, is it sending to much current, causing parts to go bad.
Any thoughts?
bamakodaker
