Comp not running, not cooling
OK, my refrigerator stopped cooling yesterday, Noticed popsicles / ice melting. At first i heard the fans and thought it was running, but upon opening the back and placing my ear on the compressor there is no noise.
If I move the freezer temp control down fan shuts off, up it turns on.
I heard a humming from the condeser fan which was not moving, if I spin it, it keeps spinning. If I try to stop it, it will now start back up.
I checked the voltage at both points on the top relay on the compressor and both read 122vac, so it is closed.
Also HOT to any of the 3 positions on the plug below read 122vac, but any combination of those 3 do not read any voltage.
Any ideas? other spots to check?
Steve
