Compactor is noisey
I have a kitchenaid trash compactor and it compacts well. However it is getting noiseyon the crush and return cycle. It sounds like it is rubbing metl but I see no evidence of it. Model is a superba KCCC151JWH0.
Any ideas on what to check for?
Hi, My freezer does not defrost ice builds up fridg stops. I defrost it manually then it works for a while and ices up again .
My Kitchenaid KUCC151JSS0 also started making a loud "vibrating" noise when starting and returning. I removed the power screw covers, but could not see anything loose or vibrating, but it also sounds like something is rubbing. There is a lot of grease on the cardboard covers I removed and not on the screws
