complete replacement door for GE Advantium
I just got my new door for our Advantium I was able to remove the old door ,hoever with all my might I am unable to exstend the hinges to hang the new door !!! Is there a tool or trick …please anyone know?
thanks
Did you remove the microwave from the cabinet? Did you remove the outer case and the bottom panel?
If you did not then you probably have to do it.
