[FONT=Arial][SIZE=3]Hello, I need help with my Refig. Model 59675239400. The compressor will come on for a few seconds, then shut off. Then a few minutes later the compressor will come on and then shut off again. I have 124V at the capacitor.
I replaced the compressor starting device and defrost thermostat. The compressor/motor winding checked out OK. Both fans are running and control damper is working. Could this be the control board and is there a way to check the board? Or could the compressor be locked up? Thanks Chuck
[/SIZE][/FONT]
No the board is OK because you are getting the correct voltage across the compressor.
Yes that is what it sounds like.
Could be the capacitor but when I looked up the start relay it showed that the capacitor is part of the relay replacement.
