compressor wont run
condenser fan motor runs but i an not getting no voltage to compressor
Most probably a bad motherboard in the back. To confirm unplug 3 pin power connector and place a wire jumper between the mating pins labeld "line and comp." printed on the board, then plug in compressor: should run.
