Conservation 4-cycle 2-speed by crosley
I have no idea how old it is, it came with the house we’re renting. I will try to include as much detail as i can.
I put my clothes in the washer one day, and when it should have been done, needless to say it wasn’t. It was still full of water, and soap, and wet clothes (a duh right, lol).
I removed said wet clothes, siphoned out the water, squeezed out as much of the water out of the wet clothes as possible (I found out I am very whimpy), and put the clothes back in to see what all it was and wasn’t doing. It fills with water, agitates, when it’s done agitating, it just stops. No spinning, or attempted spinning, same with draining. I’ve even tried all the cycles with no more luck than what I started with.
I have attempted to try to find a picture, hoping that it might help narrowing down a model number or help someone find the problem. But I’ve had no luck. It is 36 in tall (42 including the panel with the dials), 24 inches wide, it only has 2 dials, one for the cycles, and one for the water level with the options small and extra large. I think it is standard compacity.
I have no idea where to look for the model number at. I’ve looked on the back and all sides except the bottom.
Okay… so the model number is inside the lid… Don’t mind me I have the dumb, lol.
CAWB427JQ1
I still have no idea how old it is…
The upper handle on the fridge side of our side by side unit has come loose. It looks like the top bracket is still in place but the center two brackets appear to have broken and so the handle bows and is in danger of breaking off all together. There are no screws or exposed places to remove the old handle and replace it. It looks like I would have to take off the entire door, pull out the interior, etc to get to the handle. Is there a set up instructions for doing this? Is this something I should hire a pro for?
