Control Lock
THe Control Lock Indicator light is always lit. None of the selection buttons work. As the manual suggests, I did hold down the No Heat Dry pad for four seconds. This did not correct the problem. Why is this happening? :confused:
Most likely the problem caused by a one or more stuck pads on the key panel.
In order to provide the right part number for the console assembly for your dishwasher I need the complete model number and the color of the dishwasher.
— Begin quote from Gene;16397
I think thgis is what you want as the full model number. 665.15951793
— Begin quote from Gene;16466
I also need the color of the control panel.
It is white.
The part number for the membrane switch for your dishwasher is AP3096907.
Good luck.
