Hello, I just purchased a house that came with the above mentioned range. At first I was very happy about it because it had a convection oven, but then I realized that I can’t use it because the control panel does not work properly. Some of the buttons do make a beeping sound when you press them, but you can not operate the oven because so many of them don’t work. I had a repair person come in and he told me that I needed to replace the control board and possibly the membrane also, which is very expensive. Only in parts I would have to spend over $500. But after reading some of the postings in this site, I’m thinking that maybe I don’t need to replace everything. And if I do, maybe it is possible to replace it myself and save some money that way. I would appreciate any advice about whether to try and replace the control board and/or membrane (the range is stainless steel, the membrane is gray). Thank you very much!
Related topics
Control panel problem | 0 | 1526 | August 7, 2008 | |
Some control panel buttons not working | 1 | 1897 | March 14, 2011 | |
Help!!! | 2 | 1128 | March 8, 2011 | |
Kitchen Aid Touchpanel | 2 | 1149 | October 30, 2009 | |
control board | 1 | 770 | July 22, 2010 |
