Control Panel Repair
I replaced the control panel (pt35701M665-60) on my Jenn Air range and remounted it by attaching the control panel to the end brackets. Next I attached the end panels to the range. The problem is that after I pull the sheild-he (pt#3604F383-09) under the control panel, I can’t get the shield-he to come farther enough over the shield vent (pt#74009445), so it screw holes will align over the shield vent holes so the two screws can be inserted the two sheilds can be screwed together. What is the solution?
Thanks.
gerrybill
