I need to replace the timer, which I have. It’s been awhile since I’ve worked on a washer. I can’t figure out how to open the control panel. Please advise.
Hi James
Gently pull off the end caps, holding from the top and pulling towards you, and then take out the two screws that hold the console to the cabinet.
Pull the console towards you, flip it up and there you are!
Good luck, let us know if you have any problems.
Thank You, I will give it a try.
