Conversion to propane
change dryer to propane new dryer from home depot.Change orifice with new kit #49572a kit.I,m a serviceman 30 years.This has a new burner part#w10336852 in it.I installed orifice#54 from kit.This is a new design.It seems to me is that you just install orifice and thats it.It as no place for the
Regulator vent that comes in kit.I have a nice blue flame.See no adjustment on regulator to change from nat. gas to propane.Any toughts?
More info on this topic.
http://appliancejunk.com/forums/index.php?topic=9492.0
I have a used NG model Kenmore dryer in very nice condition I bought that I want to test but the only convenient arrangement to test it is to use propane . Can I buy a propane conversion kit for this model 110.78652700, install it, test the dryer, and then put the NG parts back in without causing a problem ? What is the p/n of the kit ? Does it take a special fitting to hook up to a 20 pound propane tank ?
Yes, I don’t see why you can not do it. This conversion kit comes with the installation instructions.
  • The LP conversion kit 49572A
