I need information on how to convert my Thermador from natural gas to propane. There is no kit list, so I’m thinking it’s an adjustment to existing parts on the stove, but what?
Hi, I just purchased a thermador range and they sent the wrong one! So i was going to convert the range from NG to LP seems thermador will convert the top of the range but not the oven???
Conversion means convert everything. Otherwise it does not have any reason at all. You have to follow all manufacturer instructions. I believe it had to be converted before it was delivered. If Thermador did not do it right then you have to discus it with them. Any wrong doing can void the warranty and put you in troubles.
Well they were suppose to send me a duel fuel gas cook top and a convection electric oven. The conversion kit was for the gas cook top i guess they don’t make a conversion kit if you happen to want to convert your all NG stove to LP or LP to NG!!
What is the model number of the range?
they sent prg364edg the one i was suppose to get was prd364edg! They said you cant convert the prg364edg to lp. The only one they make coversion kits for are the prd364edg only for the top! PRD364edg which is the duel fuel gas top electric oven! I now have a prl364edg which is the one the oven is messed up Which i mentioned in my other post!
The letter "L" in the model number says that this range has been made for LP gas on the factory. Another word you do not have to convert it and you’ll never be able to use it with natural gas because Thermador does not sell such kits separate.
If it’s not working properly then call Thermador for the warranty service.
