cooktop light stays on
cooktop light stays on when controls are turned off. What could be the problem?
The light that stays on, is it one that is lit only when a surface is turned on or one that means a burner is hot?
— Begin quote from Appliance Ninja;836581
when the surface is turned on not the hot surface light
Okay, so one of the switches has a welded pilot contact. Do you have a meter to test with?
