Cooktop switch knob does not ignite
Hi
I have a GE Profile gas cooktop. One of the knobs does not set the burners to ignite - I can get it to ignite once every 20 tries or so by jiggling it a bit. I can turn on the gas on that burner and then turn another knob to ignite and it will ignite that first burner as well - the ignite sends ignite to all 4 burners at once. The problem seems to be the faulty knob control is not sending the ignite correctly to the burners? How can I fix this? I read in some other posting that I may need to change this : http://www.appliancepartspros.com/part_details.aspx?part_id=3783914 Is this the correct part required ? and can someone provide me with instructions on how this can be replaced ? Thank you very much!
Regards,
