Cooktop won't turn on at all
Hi,
I went to make some soup tonight and my cooktop wouldn’t turn on at all. None of the burners turned on and the air also wouldn’t turn on on the unit. We also tried to trip the circuit breaker to the house for the stove/whole kitchen actually and turned it back on to see if the problem was there and still it won’t turn on at all. What would cause this? Is it something that I am able to fix on my own or will I need to call a repairman in to to this?
Thank you in advance for any help on this matter.
Mary
Sounds like a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug. Your unit is probably hard wired.l
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
