cpnverting from NG to LP
We bought a used dacor: Model number :ERD48S03CH
Serial number : FA0200848
It is set up for NG but we have only LP in our house and know nothing about how to go about doing this corretly and safely. the company wont send us a conversion kit. are there any available to buy?
please help!
I found all part numbers needed for the conversion, but I do not think it’s worth it because cost for all needed parts are going to be close to $700 and they all are on back order.
how long are these items on backorder for? dacor does not sell them at all. thanks
Oven is flashing F7 error and beeping 3 times and oven goes off. Of course, this is the only error # not listed in the manual. Can you please tell what’s wrong and what I need to replace?
You either have a bad touch pad or control board. To test this you will need to turn off the unit, and gain access to the board. Unplug the ribbon cable for the touch pad. If the code comes back, then you have a bad board. If no code, then you have a bad touch pad. Here is the part numbers for both, and a link to the parts diagram. Hope this helps.
[part]AP2029572[/part]
[part]AP3155970[/part]
Control panel replacement parts for General Electric JT950SA1SS Electric range | AppliancePartsPros.com
Thank you very much! I will try what you said to do. You only gave me one part # and I think there are 2. Can you please send me the other one?
Your welcome. There should be two part numbers there. Look above each picture, you should see the numbers.
My bad. It’s still early:) Thanks Jeff:)
Your welcome. Let us know how it turns out.
