Crazy FRIG Dishwasher
frigidaire FDB1502RGC0 dishwasher set for normal wash and heat dry option, both leds are on. dishwasher cycles through wash, but never makes it to dry cycle. After wash, the leds for OPTIONS high temp wash and dry cycle start blinking and do not stop blinking until I hit cancel - which cancels everything. Open unit and water sitting in bottom. Is it a bad operator panel? Water pump did seem to be working during wash cycle. NEED HELP.
Here are your parts. Note for a RGB0 not a RCB0
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161346
Here is a tech sheet
[http://frigidaireservicetips.com/pdfs/484_2.pdf](http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154595301en.pdf"]http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154595301en.pdf[/URL]
And a manual
[URL="http://frigidaireservicetips.com/pdfs/484_2.pdf)
Try different cycle types, could be it is hanging up due to a water temperature problem.
Run diagnostics.
Check the heater, hi-limit thermostat and thermistor with a meter.
If all OK odds are it is the control board.
Perhaps try the following though it is a long shot
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
