Hi,
I have gotten more information on this. If anyone can offer any ideas, I would be so appreciative! My washer will fill and agitate, but when the pump should kick on to drain and start the spin cycle, the washer clicks a couple of times and then just sits there until in times through the whole spin cycle. Then it will try to fill for rinse, but sense it is already full (still full,) it agitates for the rinse cycle. Then, the pump DOES kick on and it DOES spin. Son I know it isn’t a bad bearing, or something mechanical associated with the spinning action. Is there a controller that I need to check? By the way, my old washer has two wash cycles. This exact same thing happens regardless of which wash cycle I choose. The model number is BW22B5V Rev 10.
