Timer cycle when I start the washer in the start position it does not always start in the correct cycle. It could be in the spin cycle or the middle of the wash cycle etc. Someone told me this is the timer switch and they can be easily replaced. I’m looking for a diagram of the washer to locate the timer switch and is this the probelm?
The first thing I would check (before replacing the timer) are the timer knob and dial (100, #7 & #8 on the [B]diagram[/B]).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=24087324&&model_id=5203524
— Begin quote from Gene;118389
The first thing I would check (before replacing the timer) are the timer knob and dial (100, #7 & #8 on the Replacement parts for GE WHDSR315DAWW | AppliancePartsPros.com.
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=24087324&&model_id=5203524)
Hi Gene,
I looked at the diagram and I thought that 100 is the timer switch am I incorrect? If I am what is the number of the timer switch on the diagram?
Thanks,
Ted
Yes Ted. That’s right and the timer AP3883985
