Cycles Wont Spin
We Start The Washer And The Necessary Water Gets Fill Up To Run However, Nothing Happens. We Tried To Start The Cycles Manually And The Washer Still Does Not Runs.
Do You Have Any Suggestion To This Problem.
Regards,
Joe F
A common failure is the lid switch. I would check there first.
