We broiled in the upper oven with the oven door slighly open and the oven over heated. We reset the oven, by reseting the red button inside the oven, and it worked fine. Shortly thereafter, the oven began to beep. We’d lock the keypad so it was OFF. But now that doesn’t always work anymore. Even when you have the key paid locked and the display says "Off" in red, it will beep, unlock, and continue to beep. We are also getting the F-O error. It typically beeps more after the oven has been used and oddly at night. The clock also can’t be set because the buttons don’t work. Sometimes, when using the oven, it will shut off, but you can start it back up again no problem. When it’s started, it typically works just fine, albeit it periodically shuts off.
Questions:
Do I need a Stove / Oven / Range Membrane Switch Panel - 62678B? I think so.
Is the Stove / Oven / Range Membrane Switch Panel - 62678B also known as the control panel? Again, I think so.
[COLOR=#0066cc]Is it likely to be anything else, such as the Stove/Oven/Range Relay Board - 92029?
[/COLOR]
(javascript: void(0)
