The controls for RV36S don’t respond to keypad depressions. An internet blog suggested that if pins 12 and 13 didn’t indicate closed when the up/down keypad button was depressed the problem was with the keypad.
I ordered part AP3363596 from AppliancePartsPros and installed it. Unfortunately the unit still does not work.
I notice that the keypad that was sent to me specifies pcb and rvr models. I have an rvs model. Is this a potential problem?
Could the depression pad itself be a problem? I did not get a new one, but did clean the old one.
What the best way to test for whether the PCB is properly functioning?
My unit had been, for lack of a better term, flakey for a few years (blinking lights, incomplete resets, etc). Now there is no light on the keyboard at all, and no response to any keypress. I ran the troubleshoot procedure – found the right voltages in the right places, fuse is good, and there is continuity between the fuse and L3. I’d guess it’s time to replace the main controller board. Any other thoughts? What might be the part number of the board?
