dacor wall oven malfunction
I am getting an error code of F0. According to the troubleshooting guide this indicates a shorted key on the membrane touch pad. It indicates as a diagnosis/repair to check the membrane function against the schematic. Replace control panel assembly if membrane is shorted. The touch pad will not register anything but the timers. Wondering if I need to replace the touch pad or just the circuit board that the touch pad connects to. Any help or direction would be appreciated. Thanks, Jeff
I have never worked on these so cannot be of much help but I can at least get you some info.
Have you tried removing power from the unit for a couple minutes to see if it will reset?
The normal way to troubleshoot problems like this is to check the keypad output with a meter.
Following is a wiring diagram that comes up for this series of units. The problem is that I do not know if it applies to your unit as it looks like it is for a double oven.
http://ww1.dacorservice.com/PartsCatalog/docs/ProductModels/430/Diagnostic_Manual.pdf
If it does apply then you could:
Unplug/remove power from the unit.
Then disconnect the keypad at the control board and check it’s key outputs using resistance.
You may want to try the following, though I doubt it will do anything as the error code is for a shorted key and not an open key.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Another possible way to troubleshoot is to remove power from the unit, unplug the keypad and then power it up again. Just be careful that the end of the keypad harness cannot short to anything.
If the error disappears then I would replace the keypad.
If the error is still there I would replace the control board.
A bit of a crap shoot but your odds are better.
Although your unit does not come up AppliancPartsPros probably sells parts for this unit.
