Defost Problem
I have a Samsung RS2630WW side by side refrig. It will not defrost. I unplug it defrost with hair dryer and the coils are frozen over in a week. What part do I need to replace to fix this problem?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS2630WW
Here is a manual that should help
http://www.servicematters.com/maytag_library/docs/SAM0069.pdf
Try to force it ito a defrost cycle.
If the defrost heater heats up, then the board probably needs repalacing.
If it does not heat up check the heater and the defrost thermostat (bi-metal) for resistance.
Note the defrost thermostat must be checked when frozen, it opens just above freezing.
I have already replace the board (first) and then I replaced the heater.
How do you do a force Defost. I also have notice that the refrig freeze department show alot of cold air (white) after day of being defrosted with hair dryer.
If it does not heat up check the heater and the defrost thermostat (bi-metal) for resistance. How do you do this?
Where is the defrost thermostat?
Page 21 in the service manual
If the frost is on the the evaporator coils this may be normal.
Some frost is on the evaporator coils is normal, It is only a problem when it gets heavy enough to stop air flowing through the coils.
You need a meter.
Disconnect one side of the device you are measuring and then measure across it
Defrost thermostat should be 0 ohms when frozen. Note it opens just above freezing so it must be frozen
The heater should be about 20 ohms
How do you do this?
It is usually clipped onto the evaporator coils
Looks like this unit uses a glass type defrost heater.
Theses are not very reliable and often you can see where it is blown.
