Hi, the condenser in the inside-back of my bottom freezer compartment is icing over. The heating element has continuity, and I replaced the defrost thermostat thinking that was the problem, but still getting the issue. I guess it’s the control board, but are there any other tests I can do to confirm it? I’d like to force a defrost to make sure the heating element works. How do I do that? Anything else you suggest before I drop $150 on a control board I can’t return? Thanks a ton! -Jon
Related topics
freezer wont defrost | 3 | 955 | April 12, 2010 | |
Amana Bottom Freezer Defrost Cycle Help | 6 | 4709 | October 3, 2009 | |
Forcing a defrost cycle | 7 | 3457 | June 19, 2013 | |
Amana Bottom Freezer Icing Up | 2 | 3674 | January 12, 2012 | |
Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out. | 3 | 5144 | January 10, 2010 |
